Ag irrigation water pump?
I have one of those Berkeley B3ZRM belt drive water pumps. It has four belts and a big pulley runs the little pulley on the pump
itself. My question is how much PTO horsepower is required to run one of these? I use it to run a handline and the inlet side is
charged from the canal. Anyone else have one of these?
I think you would need a 40-50 hp. tractor to run that pump efficiently. I run a 3 inch Gorman-Rupp pto pump easy on a 50 hp. tractor.
Really depends how many lines / heads you want to run.... with in reason.
We have one we hooked up to our first cranberry field when we were waiting to get the electric hooked up.
It was in good shape at the time. Had it on the MF 165 and it was all it could do to run 8 acres of solid set sprinklers 50x50 spacing 1/8 nozzle. It was wide open and we were lucky to get 40 lbs.
If its not worn and your only running 20-50 sprinklers it would be fine with a 40hp tractor.
The biggest problem is priming. We either piped in a 2 Honda trash pump to prime it or set a tank of water above it with a hose and tap to where the primer is. Makes life much easier.
Grant.
I have a 5 x 5 inch suction and discharge Long brand pump. I normally run 2 hose traveler reels at the same time with it. The guns on them are Nelson 150's. It takes a 130 hp tractor to keep the pressure up once everything charges up with water. It's better to have a little too much tractor than not enough. Also have another 3 x 4 inch Berkeley that is 540 pto. I put a 1000 pto adapter on it to be able to let tractor stay just off of idle. That combo works good on a 90 hp tractor. Saves a bunch of fuel also.
Another tip I learned, if you put a foot valve at the end of the suction line, it can be primed very easily with a nurse tank and pump. If everything is in good shape, usually don't have to prime it but 1 time until the suction line is disconnected.
You're right, I can only run about 20 #30 sprinklers at a time, otherwise not enough pressure at the pipe to get decent coverage.
those pumps use to be all over around here.. we ran 1/2 mile worth of wheel lines with one hooked to an ID6 international for many years.. nozzle size and leaks make a big difference on what coverage you get..
poke here
