Air compressor oil
rrman61
I have a mills 2 stage(2 cylinder)air compressor powered by a 5hp electric motor.the compressor is heavy cast iron.what kind of oil should I use in it?a heavy engine oil or gear oil?
I spent 22 years owning a tire shop. Please use Air Compressor oil in it. We used to get it at NAPA or American Auto Parts. It has non foaming additives in it along with additives to keep our air compressors operating properly.
You can buy oil that is labeled Air Compressor Oil but basically all it is is 30 weight non-detergent oil. The detergent in engine oil tends to foam in an air compressor.
rrman61 , A GOOD QUALITY 30 wt non detergent will work great.Keep it changed often and best to use a regular maintenance schedule to keep things in tip top shape.
