Allis CA wide front question
jpi72
I am considering buying a CA with a narrow front. The same seller has a CA with a wide front for sale. How hard is it to move the wide front form one tractor to the other?
Joel
If you have basic mechanical skills, it's easy. Make sure you block the front end good and soild. We have a C that we have had a wide front, narrow front, and single front wheel on at different times. CA is not any different other than the tapped holes in the front of the bolster...so a C front end will also work on your tractor...but a CA frontend won't work oon a C without modifying the frront end sheet metal.
I put a CA front on my C I used as a pulling tractor and cut the grill off.
