Alternator shaft sizes
37 chief
I am going to buy an after market alternator. More likely from china. My alternator pulley size is 4 inches across the front. The aftermarket one is 3 inches. Which will make it spin faster. Will this be a problem? It has the 5/8 width pulley for my JD belt, so the belt will fit. Will the extra speed make a difference? Stan
The extra speed will be a plus when used on a governed tractor engine.
Some times alternators need to be spun up pretty fast to initiate the charge, the smaller pulley will help.
As long as the width is right I would go with the smaller pulley. You may need a shorter belt though.
98-NAA5825 pulley YT has them... Most all of the replacement alts have a 3/4" pulley that's called a universal 5/8 and 3/4" pulley its a 3/4" pulley : ( and flat wrong for a 5/8" belt...
Yes smaller is better for a alt...
