I saw the posts on the inching pedal and thought I would post a question of my own.
The inching pedal spring in mine is broken. I know it is the spring because I took out the broken part when I changed the oil/filter after I bought the tractor. The tractor does drive using a bungee cord to pull the pedal back, but there is no inching using the pedal. There is only about 1 inch of response in the pedal, meaning if the pedal is not all the way to the top, it doesn't engage and drive. I thought I read where pressing the inching pedal slightly is used for inching along. Is this correct? or is the brake used with the inching pedal fully engaged? Should there be more pedal travel with different levels of response from the inching pedal?
I would like to fix this and read the post about taking off the top cover of the transmission. I believe mine (to fix the spring) is accessed through the cover on the bottom. Is this right? Also, are springs available somewhere? I believe I asked at the dealer and they said they are not available.
Any help would be greatly appreciated.
Oh, and I have the service manuals, but I am likely looking in the wrong one.
