Any CAV pump Experts?
Kirk Grau
I have a Ford 3600D (pretty sure that makes it a CAV DPA pump) that has been leaking fuel into crankcase for a while. Since my usage is light (hobby acreage) I have been monitoring and refreshing oil frequently as well as trying to find/fix problem. Replaced the "Thermostart" hoping that would be it, but still had fuel in crankcase. There is a seal you can get to in the injection pump without removing the pump so it was replaced without any improvement as well. Removed the pump over the weekend and replaced the seal behind the "drive hub". Mounted pump and bled system to get it running and now engine just runs at max RPM (or maybe faster). Am assuming I must have somehow messed up the throttle/governor somehow, but sure don't see what I could have done since I was not near any of those parts. Tractor was running fine before I started messing with it.
Any thoughts on DIY fixes or do I need to breakdown and take the pump over to the local diesel shop? Sure would be nice if it was something I could do myself. I have the Ford Service manual which describes the full rebuild with some pictures just not sure if I might need specialized equipment or tools. I might just remove the pump again and take the cover off to see if something obvious broke or came loose during my efforts. Looking for a little encouragement and insight.
Thanks,
Kirk
As I understand these beasts the injector piping is all accessible, unlike some of the earlier Ford diesels that had the return line under the valve cover that would cause similar problems.
No have not looked at injectors as of yet, trying to attack the less costly/more liekly possibilities first.
Thanks,
Kirk
The most likely source of fuel dilution is going to either be a leaking fitting, where the fitting is within the engine, or a leaking injector. Even if, let's say the injector pump, were leaking. How would the fuel get into the oil?
Agreed and I don't think my approach is too far off from where you are going. A malfunctioning Thermostart (and mine was not working anyway) could have been passing fuel directly into the air intake and eventually down to the crankcase. I will admit that the first seal I replaced in the injection pump was not a very likly candidate after I saw what it was doing, but the most recent seal is the one directly between the fuel pump and the crankcase and could very likely be the culprit. If this does not get it corrected, I will have to move on to the injectors themselves.
Thanks for the thoughts,
Kirk
I am no expert, but I have dealt with the CAV / Simms pumps on my 8000, 9000, TW 10 tractors. Of course these are 6 cylinder tractors and I have no experience with the 3 or 4 cylinder models. But my pumps have a diesel fuel lift pump located on the side of the injection pump. The lift pumps have been a problem with fuel dillution, especially if someone has added a methanol winter agent to the diesel fuel. The rubber diaphram will begin to fail and the fuel goes inward into the inject pump camcase and then into the tractor engine oil on TW-10. On the 8 and 9000 tractors, they do not share engine oil with the injector pump but have an overflow tube on the engine side of the injector pump. So you dillute the injector pump oil and then begin spitting it off as it gets to be almost straight diesel lubbing the injector pump. Your system is probably similar to one of the above.
As to the governor control, I THINK it has to do with some sliding plate above the injector pistons. This may have become disconnected when you disassembled the top. I really doubt the "faulty injector" idea, as they would have had to all fail at once. You'd have better luck playing "Powerball". When we have had injector failure, we get a stumble on one cylinder and a bunch of black puffing smoke from the exhaust. And they never give a run-away RPM surge. You may still have air trapped in the injector lines. The CAV pump will purge itself and the injectors, meanwhile giving a high idle RPM with no power, but no black smoke. This may be what you are experiencing.
Best of luck,
Paul in MN
Not familar with your tractor model, but does it have a lift pump or gravity fed fuel delivery system. On MF tractors they are infamous for the lift pump have a ruptured diaphram which leaks diesel directly into the oil pan. Tom
How long until air would be purged out? I had this one running flat out for (not by choice) for 4-5 minutes. Am going to try to get back after this a little this afternoon.
Kirk
