armall c123 tractor
elibowen1959
rebuilding a c123 farmall gas engine rod bearings are stamped .060 unable to locate a replacement set, looking for a direction to get set
It is very unlikely that you will find a set for bearing journals ground undersized to that extent. Rather than finding a very rare product,
look for a good used crank, they are plentiful. Jim
Might give this site parts department a call. I don't see a listing but they may have a source.
You can buy a "crank kit", it is a reground crank complete with the correct size bearings. A crank that is ground .060" is past it's service life, asking for trouble trying to reuse it.
If any of the old bearings spun, the rods can be reconditioned, or the mains align bored.
Did you mike the crank? They used to make a .060 semi that was a heavy coat of
Babbitt & then cut it to .020, 030, .040 etc.
