Auxiliary Pto Pump
Countryrulzz
I have a ford 7000 tractor that has a rear auxiliary pto pump. I am needing to run my baler out the other side of the pump. I have got a 6 inch male spline to go into pump and fit into baler but I'm wondering how to keep it in the pump. The pump has 2 small holes in the neck but they are not threaded.
This site has what you need #115844 pto extention.
I would say you need to do one of 2 things either drill the adapter to take a pin or tap the lip of the pump in the current holes. Probably neither one is hard beyond drill able. Slide adapter in mark hole and drill. Otherwise you will need to tap the holes and then the pin would want a wire keeper through it keeping it in place while spinning.
