Axle repair
SVcummins
Looks like it did 340,000 miles ago
Can you buy those for any size or are they for just certain sizes? Reason for asking is I always buy the Stemco seals for wheel seals on semi axles and the Grit guardian has a wear sleeve with them. I still will only use Stemco seals for wheels. Best seal going. I have nothing to do with Stemco. I have used all brands of seals the Stemco will go 10 years and the rest will only go about 3 years if lucky. They cost the same money with in a dollar or 2. Stemco also has a seal with just a wear sleeve rather than the cup looking deal in the back.
Here's some info--
https://www.skf.com/us/products/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve
Like the PVC pipe trick. I have gone to an exhaust shop and had exhaust tube expanded to size. The last speedi-sleeve I did was on a Farmall C axle. Had to slide it about two feet. Worked though.
OTJ
I replied to fixerupper's thread in the John Deere forum. I'm sure this will work great for you. I had trouble with the axles seals wearing thru the sleeve every 3 years with a 610 bobcat. I was afraid of welding them up for fear of breakage. An old bobcat mechanic said do it and it's way over 3 years since I replaced the seal. The thing with the 610 is that the seals hold automatic transmission fluid in the case. The drive chains run in oil.
I've put many a one of them (genuine Speedi Sleeve) on MACK vibration dampers and other components. Looked at their catalog just now and they go up to 20 13/16!!. The big ones have a nice heavy metal cup to put them on that make a good small parts holder too.
It was about 6 oclock when I started my search for a driver and I wasnt sure I was going to find something without a trip to the muffler or iron shop
And it looks like I need to order one more speedi sleeve the other side of the axle has just enough groove I dont think itll hold the seal this side was actually leaking out and on to the tire . I just love a project that should take 45 minutes and turns into a week long after work extravaganza and costs 400$
