battery charger
wilson ind
Put charger on diesel tractor yesterday. set at 20 amps,-plan was to turn back to 2 amps after 30 min. Rembered this morning , did not reduce amps. Was standing behind tractor ,reached over seat hit starter. Battery exploded. Thanking of a true George solution, going to mount a timer on charger putting power through devise in such a way to always set time. Circuit breaker needs replaced also. Good charger, just needs attetion. Maybe will take thing to George, let him figure best solution and pick up both green and ripe tomatoes.
Those green tomatoes may be frozen tonight.
Because of you, I'm out of used diodes.
I haven't seen any new diode packs with just 2 diodes.
Everything I've seen on Amazon are 4 diode bridge circuits.
Or single diodes. Not cheap. I had to repair my last charger with 2 diodes mounted on an aluminum heat sink.
I had a circuit breaker go bad today on a different charger. It was a 35 amp. I replaced it with a 30 amp breaker.
I used a 20 amp fuse on my most recent old school repair. So far so good.
For diodes just us the ones in an alternator some of the older ones you can press them out to use individually, or just use the bridge trio.
Old,
I'm cheap, All my diodes were used ones I scrapped out of electronic equipment I was given. My inventory is depleted.
I think half of my inventory was used to repair Wilson's chargers.
I'm cheap, but Wilson is gives cheap another meaning. lol
