militiaman11
Hello. I have a 1961 IH 340 Utility. Posted about it a few times on here now. I'm currently experiencing strange behavior with the battery not charging and i wonder if anyone can shed light on this. the battery is brand new, and i have recently had the alternator tested. it checked out fine by the auto parts store, but i don't know if that can fully be trusted. recently i had the alternator off to change the belt and do some other things, and when i put it all back together the battery was charging fine. measured over 14V on the battery while the tractor was running. now, mysteriously, without changes the battery sits just at 12V while the tractor is running. if i measure voltage directly on the alternator i am getting 15V while running, but at the battery i'm getting 12V. One question i have here is that the wiring diagram in the manual shows a positive ground. This tractor was converted to an alternator, and has had some wiring hacks done over the years by previous owners. but should the tractor still be positive ground? it is currently a negative ground, and has been since i purchased it. i have checked all connections and they all seem clean and tight, but the lack of charging suggests to me a loose or broken wire. or maybe the alternator is now failing. any help would be great. Thank you ahead of time.
