Racing sanctioning bodies have differing opinions on this question. NHRA, for example, requires the switch on the positive side. Others mandate it be on the ground. Either one works, and there is an argument to be made against each.(quoted from post at 10:37:14 10/23/21) Ok, which cable do you put the battery cut-off switch the positive(red) or negative(black). I have had a lengthy discussion about which to use but no one knew for sure. Thanks for your advice in advance!
here is no chance of arcing when a master disconnect is being used. None, zip, nada.(quoted from post at 12:39:11 10/23/21) Less chance of arcing if cutoff switch is connected to Negative.
Unlike what another poster commented, this is not a house. This is not AC (Alternating Current) electric.
For negative-ground vehicles, connecting to Negative terminal is normally preferred.
o. That's why we have master disconnects. (along with a few other reasons)(quoted from post at 16:12:48 10/23/21) Unless there is parasitic current draw?
(quoted from post at 12:46:44 10/23/21)here is no chance of arcing when a master disconnect is being used. None, zip, nada.(quoted from post at 12:39:11 10/23/21) Less chance of arcing if cutoff switch is connected to Negative.
