Bearing number help
37 chief
I need three 2065 jj ball bearings. When I look up that number, a clutch through out bearing comes up. Any body know how I can find a ball bearing number 2065 jj. The jj must mean sealed both sides. Thanks Stan
Yep, it's a thrust bearing.
Do you have calipers so you can get some measurements?
Most bearings are metric.
Once the bearing is identified that will narrow down the suffix meaning.
Here are the measurements. It is made by federal BW 2065 jj is the complete number
Id is 1.3395
Od is 2.675
Width is .826 Hub is a little wider .900
Well...
I narrowed it down to a SKF 34X68X21/24.
Appears to be special, Ford Mustang maybe. Evidently there is no number assigned, just a dimension. That sent me to some foreign language sites.
If it is for a Mustang try looking it up as an automotive application. Or take the bearing or dimensions to a bearing supply, they may have more resources.
Sorry couldn't be more help.
