Belarus hard starting...
Bought a 1987 Belarus 560 last year. Runs strong, uses no oil - here"s the problem: HARD starting, and LOTS of black smoke for 1-2 minutes when it does start. Once it clears everything seems fine. I"ve replaced the glo plugs (indirect inj engine) and the injectors (4) with new. Glo plugs ARE heating. Compression is good. Cranking rpm seems fine. Could the injector pump be at fault (I can buy a brand new one for $675)? Any suggestions?
Thanks, Goober
Probably not anything wrong...it's a Belarus and that is how they start. Under normal temp. conditions, forget the glow plugs and give it a shot of ether through the air cleaner; UNDER NO CIRCUMSTANCES EVER DO YOU USE THE GLOW PLUGS AND ETHER!!!!!! That will result in the least in engine damage, and worst injury. If it's real cold and you have to use the glow plugs then it's just the way they are...think they start hard? Try starting a British B series Farmall Diesel!
