Bermuda hybrid seed
Ron in AR
Anyone have any experiences with useing a hybrid bermuda seed (as opposed to sprigging)? I've got VERY rocky ground and tried some sprigging a few years ago. Didn't work very well at all. I've been looking into a seeded variety of a hybrid bermuda that I could no-till in. The link below is one of the varieties I'm looking at. Any info appreciated.
Seeded hybrid bermuda
The description of the Rancho Frio Bermuda shown on the web site states that part of it"s mix is 5.25% Regular Cheyenne Bermuda and 3.25% SWI-810 Bermuda (Cheyenne II).
In 2007 we took an existing field that was originally sprigged back in the 50"s with Coastal Bermuda and seeded it with Cheyenne Bermuda.
The photo below shows the results the first year.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202007/?action=view&current=IMG_0709.jpg" target="_blank">
IMG_0709.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202007/?action=view&current=IMG_0710.jpg" target="_blank">
IMG_0710.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202007/?action=view&current=IMG_1217.jpg" target="_blank">
IMG_1217.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
This year we over-seeded another area of the same field with Cheyenne Bermuda.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202009/Discing%20and%20Culitpacking/?action=view&current=IMG_1298.jpg" target="_blank">
IMG_1298.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
The photos below, taken last Sunday, show this year"s results.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202009/New%20Grass%20Seed/?action=view&current=IMG_1632.jpg" target="_blank">
IMG_1632.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202009/New%20Grass%20Seed/?action=view&current=IMG_1631.jpg" target="_blank">
IMG_1631.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202009/New%20Grass%20Seed/?action=view&current=IMG_1630.jpg" target="_blank">
IMG_1630.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202009/New%20Grass%20Seed/?action=view&current=IMG_1629.jpg" target="_blank">
IMG_1629.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Hope this helps and good luck with whatever Bermuda grass you choose.
I would be concerned about the giant bermuda because, to my knowledge, it will revert back to common in 3-5 yrs. Common is what you see in people's yards and does not get as tall as coastal.
I don't know anything about Mohawk, you should research it to find out if it will maintain its hybrid qualities or if it will also revert back to common.
Since those two varieties make up the bulk of the Rancho Frio mix, I would definitely find out before you made any decisions.
The Cheyenne is guaranteed to maintain its hybrid qualities and not revert back to common.
Cheyenne is very expensive. I think we paid around $180 per 25 lb. bag. It can also be hard to get.
We originally seeded at the recommended rate and I was not happy with the results, way too thin. I would recommend at least twice the recommended rate.
The spot that we did this year, the last photos, was seeded very heavily. I think I used 30 to 40 lbs. of seed, but as you can see, the stand is very dense. We also applied 13-13-13 fertilizer every two weeks starting in mid-June and watered it using a tank mounted on the tractor.
If you will go back a couple of days on this forum, I think on Monday, James posted pictures of this area that show the tractor and sprayer I used.
Before you purchase any hybrid bermuda seed, be sure to find out if it will revert back to common. If it does, don't waste your time or money. Make sure your hybrid will remain a hybrid. Also make sure its recommended for your area and soil type.
What part of Arkansas are you in? I'm in NE Arkansas, The only problem I've had with sowing Bermuda seed is winter freeze out. I don't know about all varieties but common need 2 years to develop a root system to hold up to our winters. I've tried Cheyenne a couple of times and haven't had it last through the 1st winter. I'm probably on the northern edge of Bermuda's range. I sprigged some Hardy Bermuda about 20 years ago that has held up fairly well and it comes out 3-4 weeks earlier than common but doesn't get as tall. I think that common is hard to beat, If you fertilize and can get the rains 3 cuttings is normal. I've got a neighbor that may get 5 this year, he's already got 3 and got 4 bales per acre each cutting (4x5 JD bales). But I've never seen a summer like this. Check with your extension agent, there may be someone locally that has had some experience.
Doesn't sound like rocky soil to me.
ADAPTATION: Across the southern 1/3 of the U.S. from California to Virginia. Including Oklahoma, Kansas, and Missouri to Virginia areas. Particularly well suited to sandy soils, but will thrive in most well drained loam soils.
The nitrogen will kill you in cost per acre.
Why not get some Tall Fescue from Oregon will grow almost anywhere with one small amount of Fertilizer in the spring and it will feet 5 to 6 ft. tall will yield up to 4 tons per acre. Plant it once and just watch it grow.
Walt
PS makes good Football fields also.
I'm about an hour due east of Fort Smith, just outside Clarksville. I've already got some common in my fields, but I'm looking to improve my stands for quality and quantity. I regularly get 4 cuttings a year. I sell my hay to a wide variety of customers, cow, horse, and dairy goat. Like I said, just looking to improve things.
