Hey folks! New kid on the block (well, at least here). Son obtained a Bobcat 743....I think he paid a bit too much but he got a great heavy trailer with it that makes up for it.....so, has some issues that need addressed.
This thing is HARD to start (understatement). Replaced 3 glow plugs but over past 3 days, I have been unable to get it to fire. (even squirting WD-40 or oil/diesel mix straight into intake). No ether, not with glow plugs....
It appears to me that the lines from the injector pump to the top of the injectors (high pressure) may bleed when not running (top of pump all gummy)....it has ran within last two months but I've spent past 3 days trying to start.
I'm an electronics geek, not a mechanic so bear with me. I cracked open a line and had air bubbles which leads me to believe the high pressure rail/fuel line needs bled...air in line, not enough oomph to pop injector AND atomize fuel well enough to fire (my theory, as I said, not mechanic).
The top of the injector pump is all gummy...I was unable to view it when running so don't know if those lines actually leak under pressure but they do appear to be bleeding down when not running.
I'm trying to not have my local Bobcat dealer retire early but don't know any good diesel mechanics. Willing to replace these lines or get the parts to redo the ends (don't know if the lines are flared so may need to do the whole lines). I'm willing to toss a few $$ towards doing this more minor work....has 5k hours which is a bit high but not needed for serious day to day operation so I don't think serious work required.
I have gray smoke but no attempt to fire. Had to replace the fuel shutoff cable (the old one was just plain froze up) and you'd question my sanity if you knew what I had to pay for a replacement....didn't have any baling wire handy though (do they still even make baling wire?)
Don't have manual on that engine and not diesel smart, just observing what I see. These do tend to have hard start issues but they are a solid and simple machine (pre-electronics everything).
Will bleed the lines today (friend coming over to handle the starter....I don't have a remote cranking cable...could make one but too lazy...and he works cheap.
Sorry so long winded, brevity is not my strong suit (I don't get out much).
Any suggestions are more than welcome. I can leave the glowplugs off and use ether but prefer to not if I can get away with it. Murphy lives with me so I'd disconnect the wire to the plugs anyway....
Just wondering if I'm out in left field or if this is feasible possibility that those lines are bleeding down when no pressure.
Thanks for all comments, advice, solutions....
Tim
Tim
