Long time lurker on these pages. I have a 1951 Ford 8n, wasn't running when I acquired it. The engine had been totally varnish locked. The old head appeared to to have been cracked and welded, and the water temperature sensor was located in a pipe welded to the head. Based on this, I decided to remove and replace the head. After a starter rebuild, and a great deal; of Marvel Mystery Oil / Sea Foam we were able to spin the engine using the starter, which was a positive sign.
However, after thoroughly cleaning the block, I noticed that the cooling hole between cylinder 1 & 2 appears to be filled with brass. The brass appears to abut up to the cylinder sleeves. I am thinking that the engine may have cracked and this was the previous owner's repair?
Is this just going to cause it to run a little hot, or is the engine basically trashed at this point?
![mvphoto12643.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto12643.jpg)
![mvphoto12644.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto12644.jpg)
