broken bolt broken screw extractor ... what next?
Ever hear of EDM?
Yeah, I was quoted over $700 to remove the 3/8" bolt and ez-out from the axle housing on my Farmall Cub using EDM. That was over 10 years ago so I'd bet the price has gone up significantly. It's truly a method of last resort, only to be used on something irreplaceable.
A brand new top of the line Toro Recycler 22" cut mower is $450 at Ace Hardware. For comparison.
Have you considered just re-locating the handle?
You say you get at the back of the fastener?
Why?
I'd look into making a couple of flat plate brackets.
Joe
here is a set of drills from promax
OK, what exactly is a 'platinum' drill? I think we can safely assume they're not made of platinum; if they were they'd be even more expensive.
Here is what they say on their website:
"This innovative kit boasts special platinum tooling, meticulously crafted to effectively and efficiently drill out even the most stubborn extractors."
Meticulously crafted? Must be made in the USA. Looks like Pittsburgh.
You might look into a product called Rescue Bit.... Broken tool extractor. It is designed for a problem like yours. I haven't used one but it looks interesting. Hope this helps
I see enough there that I would get a corner of a chisel on that extractor and a large hammer should work one or both loose after spraying it down with wd.
Yeah, I tried punching the extractor to loosen it. No success.
I tried punching it at an angle, to spin it backwards. There just wasn't enough to get a good blow directed at the right spot.
Think about buying an inverter welder for 60 to 110 and up bux. I weld alot of stuff with a 110/220v model. 1/8" rod and I can melt through quarter inch mild steel like a cutting torch. Can burn a full stick without it shutting down, do a little chipping, and keep going with more. I can't make those cheap wire welders work.
Search the threads here on inverter welders. Saw one just now on Amazon. Ssimder stick welder with pulse arc 110/220v for 110 bux and they had a cheaper one for 60. If I was buying another one, I would end up comparing it to 50 others and read 300 reviews before I buy anything on Amazon. The pulse arc may be a good feature to have.
The root cause of this problem was galvanic action. Aluminum and steel do not play well together long-term. Using an EDM/electronic discharge machine is a possibility.
