Camper Solar
John M
Since you guys know this stuff - Guy here at work want to use his batteries to run a coffee pot, etc. Wants to be able to use any of the outlets in the camper to do that, and keep the park power. How can he do that?
You say he wants to keep the park power?????????? If he's plugged into 120 VAC park power why wouldn't he use that ???? Why use the 12 VDC batteries plus an Inverter to manufacture 120 VAC when he already has 120 VAC ????
If he wants to use his house battery bank (NOT park power) to power a 120 VAC device he would need an INVERTER that uses 12 VDC batteries and Inverts it into 120 VAC. HOWEVER any high power heating device like hair dryer or coffee pot or microwave or heater WOULD DRAIN BATTERIES QUICK and its best not to draw them down over 50% of their capacity. For every amp of 120 VAC use he would draw around eleven amps out of his batteries,. If a 1500 watt 120 VAC appliance were used from battery and inverter power, that would draw like 138 amps out of his battery when running. YOURE TALKIN ONE HUGE BATTERY BANK AND A HUGE INVERTER
They make 12 VDC coffee makers why not use that ??????????????????
SURE anythings "possible" given huge enough battery banks and a huge Inverter and also a 120 VAC to 13/14+ VDC battery charger but this just is NOT very practical, NOT cost effective, and NOT very efficient
Further if he wants any of his RV outlets that are powered using his batteries and an Inverter he needs a safe and proper transfer method like a transfer switch or manually plug in and out.
This is just soooooooooooooo wrong in sooooooooooooo many ways Im not going to spend time educating him and explaining it all.........? If he is totally out to lunch on RV power and batteries and Inverters and transfer switches etc its best he hire a professional
John T RV owner of 49 years and frequent dry camp boondocker currently running with 1080 watts of solar (four rooftop panels),,,,,,,,,,,,Three AGM batteries in parallel for 520 Amp Hours,,,,,,,,,,,,,,,an MPPT Solar Charge Controller,,,,,,,,,,,a 2000 Watt Inverter,,,,,,,,,,,,an 80 Amp smart 3/4 stage Converter/Charger,,,,,,,,,,,,a 2800 Watt Cummins Onan Genset
The guy at work would need one battery, enough to start his car or truck, and head to the nearest McDonalds or 7eleven for that cup of coffee....
Let me make it easier. He wants to use some 120volt appliances off of 12 volt, but keep the ability to use 120 volt when hes at a park.
It has a converter, 120 to 12. He needs an inverter to go from 12 to 120, but he needs a transfer switch between the 2, and he really should NOT try to use the current outlets. Right? But he could wire up the inverter to separate outlets to use 120 volt appliances, and be safe.
Hi again John, new questions:
"Let me make it easier. He wants to use some 120volt appliances off of 12 volt, but keep the ability to use 120 volt when hes at a park."
NOT A PROBLEM he can run some Inverter powered outlets to feed certain loads and that will work IFFFFFFFFFFFFFF he has sufficient battery and Inverter power and sufficient means to keep the batteries charged........
"It has a converter, 120 to 12. He needs an inverter to go from 12 to 120, but he needs a transfer switch between the 2, and he really should NOT try to use the current outlets. Right?
Sounds pretty good anything can be configured to work, he can use existing outlets if their feed is properly transferred or easier to run separate dedicated outlets fed ONLY from batteries and Inverter
"But he could wire up the inverter to separate outlets to use 120 volt appliances, and be safe."
YESSSSSSSS as long as he has enough battery and charger and Inverter power he can do this but I hope he realizes any heating device creates one HUGE load on 12 volt batteries and Inverters ITS AN INEFFICIENT IMPRACTICAL METOHD EVEN IF SURE IT WILL WORK...?..
Hey I dry camp and use 12 volt batteries and an Inverter all the time but I DO NOT run high power heating appliances !!!!!!!!!!! and I have three huge 129 Lb AGM Frame Size 4D 12 volt batteries and 1080 solar watts and a 2000/4000 Watt PSW Inverter..............WHAT HE WANTS TO DO IS CERTAINLY POSSIBLE regardless if its efficient or cost effective or anything, its his RV and his choice not ours
Nice chatting with you John, I think you understand all this better then your friend !!!!!!!!!!
A simple solution, just have one extension cord that either plugs into the park outlets, or into the inverter. That way it can never be connected to both at the same time.
But as has been said, don't expect much from the inverter. It can only run small loads without over amping it and draining the battery.
I have an inverter/battery charger in my RV, and its all done automatically. If you have shore power, all the outlets are provided 120, and the inverter is out of the picture. If no shore power, the inverter will supply 120, and will run small appliances (can opener, TV, clock). But if the current demand is too large for the batteries to handle, the device simply won't work. Then you mutter "more steam" and crank up the on-board generator.
Further example- I have 2 air conditioners. If you're on 50 amp shore power, both will work at the same time. If on 30 amp, only one will work, and if you want both, you have to start the generator. On generator only, just one works.
Inverter is a Xantrex, and cost about 1200 bucks (all that "smartness" doesn't come cheap). Not one of the little ones from HF that you put under the hood of your pickup.
He needs something like this;
3000W 12V PURE SINE WAVE INVERTER CHARGER W/ LCD DISPLAY
SKU: R-INVT-PCL1-30111S-BC
$899.99
Free shipping*
And enough battery to run it.
Tell him to join airforums.com
It's all about Airstream trailers but there's some really smart people there and a lot of info about solar power in the archives if he wants to research it.
I face the same dilemma at times. No electricity to run the electric perk.
So I have a secret stash of stuff including a perk that works on the principal that if you put water and coffee in it and put it on an operational stove, in a short time the aroma of coffee will fill the coach.
No batteries, no generator, no annoying the neighbors, Just a nice hot cup of coffee.
Stan
We had a power outage at the cabin recently, and I keep a 160 watt inverter in the car to charge my laptop. I hooked it up to the boat battery in the garage and ran a cord into the cabin. we were able to run a TV, lamp, antenna booster, and cell phone booster for the 2 hours the power was off, worked great! Now to run a coffee pot you would need a much larger inverter and battery, I would make the coffee on the gas stove!
I have a small motorhome (on a 1978 Toyota chassis). The power cord b built into the RV that is meant to plug into shore power or park power is a conventional 15 amp, 120 volt plug. When I camp off-grid, I just plug in my motorhome cord into an inverter and then all my builty-in outlets work.
Note that bigger campers with air-conditioners use bigger plugs, so to do what I am doing might need an adapter. You can buy a inverter rated 2000 watts continuous and 4000 watts surge for $130. A 1000/2000 watt inverter for $90. Note that a 2000 watt continuous duty inverter can make a steady 15 amps of AC power. So the limiting factor is your battery bank.
There are much more expensive "full wave" or "sine wave" inverters but for running a TV or coffee pot or lights, a cheap mod-wave works just as well as a so-called "true sine wave."
Keep in mind that inverters turn them selves off if battery voltage drops below 11 volts - even if just for a fraction of a second. Batteries meant to start a car or truck are designed to drop to 9 volts when used hard. THAT does not work with an inverter that turns off at 11 volts. For that reason, if you have any high-draw appliances like a big microwave oven, you need a lot of battery power. At least 220 amp-hours worth.
He's going to need a LOT of batteries to run a coffee pot. I use a small inverter to operate the TV set when off the grid, but even that quickly depletes the battery. There are inverters that do what he wants to do: Use shore power when it's available but automatically switch to batteries when it's not. But they are not cheap, are fairly complicated to install and require plenty of battery capacity.
We have two Farberware percolators in our camper, one stovetop and one electric. The stovetop one is slower, so we only use it when we don't have shore power.
It s totally doable. I have 3 800 watt panels on my trailer with a 60 amp charge controller and 0 gauge cabling. That is hooked to 6 6volt golf cart batteries, 660 amp hours total. I installed a 2000 watt pure sine wave inverter and and a monitor to keep track of batteries state of charge and solar production.
We dry camp for weeks at a time and run the waffle iron, microwave, multiple TVs, cpap, etc.
The solar system will charge the batteries to full power from 50% discharged by early afternoon on a sunny day. I only run the generator when we need the air conditioners.
