Hello everyone.
I'm having a issue and I'm hoping you'll be kind enough to give me your opinion on this issue.
I had a manifold leak start so I immediately bought gaskets and was ready to replace them. When I took off the manifold I noticed some pitting so I posted on here and asked what you all suggested. It was said that I would need a new manifold but could use the one I had since I already had gaskets in hand ready to put on.
Royse was kind enough to send me a different manifold that had a better condition flange on it. It was also a different style of manifold. His being more like factory style.
I bought the studs (1 3/4" long) that you guys suggest to put in and replaced the bolts with those studs and brass nuts. I installed the manifold and gaskets and everything seemed to go great and was really easy.
I finished up the install and tried starting it and IT WAS LOUD.
I knew I had an exhaust leak at the manifold because I could feel air from the bottom side of the manifold with my hand. I have taken off the manifold and reinstalled it at least 3 separate times now and I can not figure out why I am getting this air leak.
When I put the manifold on and look up from below it appears that it is making a clean connection with the block but obviously it's not. After redoing it the several times I started to think *MAYBE* the bottom of the new manifold is resting up too close against the block surface causing a gap. (Please see pics included).
I'm wondering if the part circled in green in the 1st pic might be up against the part circled by red in 2nd pic too close causing a gap there?
That's the only thing I can think of. I have the studs in the block to the point of the smooth part on the stud. If they aren't in up to the smooth part, it's only a thread away from it.
I have the manifold tightened down nice and good also. I don't have a torque wrench but I have used a ratchet and have them snug but not TOO TIGHT.
What I was going to do today was try to double the gaskets and see if that helps. If it didn't help I was going to reuse my old manifold and see if that style has any different results.
For comparison, the manifold in the pic above that has the green circle is the EXACT manifold that I am trying to install and the one it's laying next to is the same exact STYLE I took off of the tractor.
I am at the road of explanations or possibilities. Does anybody have any thoughts, suggestions or opinions?
Anything will be greatly appreciated! Thanks in advance.
