2wheelgnnr
Ok I have a New to me ford Golden Jube I picked up last year.
Ever since Ive had it Ive had this problem.
She'll start fine and run good for amount a minute...then stall out.
wont restart again till like a min. then run like 30 seconds and stall again and so on and so forth.
Acts like it runs out of gas. so I pulled the carb this weekend and cleaned it up made sure no clogs....reinstalled same thing happening!
When it does stall I think maybe a clog in the gas line so I disconnect gas line from the tank and gas flows ok. when carb apart I check the float and the shut off assembly and seems to be free flowing.
It just acts like once you use up the gas in the carb bowl, you have to "wait" for it fill back up again?
Next im thinking of taking off the drain plug in bottom of carb and seeing if gas flows steady from there to tell me for sure that the float shut off is allowing gas to flow. it may be but just not at a good rate to keep carb bowl full of gas.
In with this plan to pull gas tank and get rid of any rust and seal it up good.
Just cant seem to get this fixed. properly. Thanks for any input into this matter. runs good and I need to fix the gravel driveway!!!!!!!!!
