Carraro axle help please
skybarnum
I have a Ford 7710 with a carraro 709-19S2 front axle. Right side hub is leaking. I have already purchased seals from the local stealership. But I cannot get the damn hub apart. Someone has been into it befor me and the sealant they used is hard and grey, frankly it looks like JB weld...
Wheel has been removed, the 2 large countersink screws have been removed. Outer carrier will not come off. It appears it is solidly connected at 2 opposing wheel studs. What am I missing. Or is it rusted on/glued on.
I went and had a beer, some lunch and thought a bit.
I put some heat to it and hit it with a bigger hammer. Hub is apart now.
Not sure what they used as a sealant but I've had seized pistons come out easier than this thing came apart.
Been a few times had to quit and rethink the situation. Get a
clear mind and get back after it. A cold beer and a look at the
manual has helped. Advise has always helped but that beer
sure hit the spot.
Worked on a lot of Carraro axles, 2 of the wheel studs have a shoulder on them and
have to be removed before the hub can come off. MJ.
