case 400 standard .
rustred
i was just wanting to know if the 830 diesel engine is a direct bolt up to a 400 diesel.
Mostly if you have the entire thing. The power steering pump bracket and throttle linkage are different for sure as are the fuel lines.
the oil filter base will have to be used from the 830 engine,, as they are different between the 400 block the 830 block,, so Do Not install the early one on the 830 block as oil flows opposite between the two, I do not think on the 400 std you will find a interference issue with the steering like I did on a row crop 400 I installed a 830 gas (284) in years ago,, a extension plate was made to shim it out on that job,, as far as bellhousings they will bolt right in, so will a 6 cylinder
cnt
