Case 450B bulldozer
martycoulas
We have a Case 450B older model bulldozer serial #3075510. Has been running perfectly until recently! The left track all of a sudden doesn't want to engage. The bulldozer will only go in one direction. If going forward it wants to go left, if in reverse it wants to go left!! Any advice would be greatly appreciated!
I cant help you, but there are a good bunch of guys down on
the crawler dozer forum that can help you !
When my JD done that, it was a steering clutch problem. One track turn all time. Sometime you can run up against a stump (something solid) pull both steering clutch leavers back and let it get in a bind or do a steering clutch job.
check out the left side as it might be some simple thing like a pin or something came out of the linkage. other wise you have a problem
inside on the left side.
