Case 600b Eagle Hitch not raising
When I warm up the tractor, I let the rpm's lower, then engage the lift lever to raise, then I raise the rpm's and the lift arms will raise about 4". I repeate the process and I may get 2" of rise each time. To lower the arms I let the rpm's go low, then engage the lower lever, then raise the rpm's and the arms lower all the way. Fluids are up, filter is clean. When the fluids are warm it won't raise at all?? Any ideas? Thank you very much.
That may well be your problem to. But on my Case I had the same problem. Turned out to be that the fluid was to low and it only picked up at times.
Now if I was on a small angle going downward. Would not pick up at all. Filled it and used it up and down. Then refilled and did this several times for it worked right.
Thank You Larry59, I will try that, my fluid never really got hot because I was plowing snow, so when I checked the oil level it was at the notch on the dip stick. But I will ad some and try it. Thanks again!
DEANO.......
