Tyler2240
I have a case 8575 3x3 baler I got it running pretty good other than it wont run right in auto. It won't read any load and does not have the arrows. Do I need to put new load cells in or is there something else that would cause this? The monitor has been refurbished also.
It would be unlikely that both load cells would be faulty so I would first be looking at any overarching issue that could render both inoperable at the same time. The con rods are also quite pricy so you want to for sure rule out all the simple stuff before condemning them. The first thing to verify is that the stuffer cycle sensor is functioning properly since if the system doesn't see that the stuffer tripped it won't know to take a load reading and the result would be what you are experiencing. Another potential cause would be the loss of sensor power or ground which would take out both load cells together. Any fault codes showing on the monitor?
