case/david brown 1210 tractor
Janice
I have a Case/ David Brown 1210 tractor 4-wheel drive with a Cramer front end. Does anyone know where I can get parts for the Cramer front end? I need the universal joints and the 2 bearings that are on the vertical shaft. Can you also give me the phone number of anyone that might have parts for this cramer front end. Thanks. Mike
Almost all bearings and bushings are standard numbered devices. There are exceptions, but few. List all the numbers on each bearing and do a google search. (some bearings have inner and outer numbers. The same goes for seals and bushings. Bushings can all be made to size from bushing material. Sometimes less expensive than original. Motion Industries, and Kaman Bearing are two sources. Jim
I expect you would have no trouble getting replacement u-joints at any good driveline repair shop. They have catalogs with u-joints and all the dimensions. Take your old joint to one and they'll probably find a match.
