I have a Case IH 385. The right brake pushes to floor. I have changed the master cylinders, checked the steel tube in the drain hose on the reservoir and then changed the 3 o-rings for the brake piston. No fix.
When I go through bleed process and clamp off the reservoir drain hose, fluid runs through bleed valve with no air bubbles. When I push the pedal while bleeding, a surge of fluid comes through. So it seems to have air out and also seems the master cylinder is working since a surge of fluid comes through. However, when I close off the bleed valve the right pedal still goes to the floor.
Any suggestions what to check next?
Thanks.
Thanks.
