Case power shuttle pump seal
Mark2359
My case 1979 case 580 ck keeps blowing power shuttle pump seal. Recent rebuild, checked regulator valve in control valve, replaced 0-rings. Checked relief valve and blew out cooling system, replaced oil. At idle in neutral/4th gear pressure at test port is 100 psi. Dont know why it keeps blowing seal. Any help would be appreciated.
Hello Mark welcome to YT! There are brand specific
topic sections on this forum. I feel you would have
better results if you placed your question in the Case
topic section. There is also a Crawler, Dozer .. Backhoe
section but it is viewed less. If you use the ..Jump to..
or ..Hop to.. drop down box seen below when viewing
your post you can navigate to those topic sections.
