Case SC Starting Issues
C.Amick
Case SC doesn't want to start. It makes gurgling nose at the manifold when you stop cranking over the engine. Could this noise be from valves out of adjustment? Im sure I need to adjust them anyway. Probably not why it won't start though.
I would pull the air intake tube off the carb to see if the float needle has stuck and filled the tube carb and manifold with gas. Second I would check for excess water in the oil bath air cleaner assuming it has one.
I will check both. Usually if the tractor is flooded, I get gas dripping from the bottom of the carb. There is an opening in the bottom of the carb on the end where the oil bath connects. Tractor is stored indoors, shouldn't be any water in oil bath. I was wondering if the manifold bad. Thanks.
What about the manifold being bad would cause it to “makes a gurgling noise”? When did it last run? Is the radiator still full? Tell more about it tractor, like ran well every year prior to this or stored inside but trying to start it after setting 5 years. Nothing says you checked the fuel and spark, very important to have those for an engine to run.
I've been running the tractor. It's been sitting in the shed for about a month since it was last started. Hasn't been out in the rain. Points fire and I installed new spark plugs. Engine doesn't spin as fast as it should. Haven't checked the radiator. I will tinker with it some more when I get a chance. Thanks for the replies.
