CaseIH 5140 hard shifting
jackw
I have a 1991 CIH 5140 Maxxum MFD with manual transmission (not power shift) that shifts hard especially when cold. It grinds going into gear on the lever with the Roman numerals (can't remember what that's called). I shut the engine off and then shift into gear start the engine and then shift the other lever into gear and then I can take off and go. Is there an adjustment or anything else to prevent the grinding.
Grinding into gear from neutral is an indication of a main clutch dragging. The very first step is to check the pedal free play, excessive free play can allow the driven disc to touch the flywheel or pressure plate. The driven disc can be warped from heat also dragging. The pilot bearing can lack lubricant causing energy transfer to the clutch shaft. All these are possible sources of the problem. If the tractor is started in gear (as you said) then put in neutral woth the clutch pushed down, does the grinding problem still reoccur when putting it into gear? if so it is likely one of the above. Jim
This is a wet clutch tractor, clutch pedal only operates a valve. And the 5140 has a 4 gear transmission with 4 powershift, giving the tractor 16 speed transmission. The power shift are controlled by solenoid switches. These tractors develop many gremlins as the age with the transmission as they age.
Jack,
This tractor does not have a clutch on the flywheel it is hyd. Do you have a neutral in the fwd.and rev. shuttle.It could be in the clutch cable adjustment, also could be fwd. or rev. clutch pack dragging. You will a service manual to adjust inching pedal and also adjust sensing switches for gear 1 thru 4th gear they are mounted right side of transmission behind the right tire.
Marlin
Im not 100%sure but I think your clutch pedal switch may be dirty. I would try to move your gear shift faster into gear and see if that works. I understand that when you clutch and it is neutral everything stops. The second you move your gear shift it goes out of neutral and then things start turning again. Other question would be is it also hard to get out of gear when tractor stopped? If yes the. It has to do with clutch pedal switch. Also something about inching valve or switch. My brother tried to explain it to me but my brain has still not got around to understanding it. I wish sometimes I could understand without drawing it all or seeing it. Words dont work for me on some things. I have a 5250 and just finished pulling the back part of the tractor and learned about the planetary and replaced button bearings. Quite simple tractor when you understand how it works. Know need to learn about the clutch pedal switch and valves what they actually do.
Bruce,
There is also as synchromesh version of the transmission. Have one of each. The synchro transmission sometimes has a slight "crunch" when shifting from gear to gear. Had it since new in 1996. Complained to the dealer. They came out, slammed it around for a while, said can't reproduce the problem. Complained to corporate, they sent someone out, they slammed it around for a while, said can't reproduce the problem.
All it achieved was pi$$ing the dealer off for "ratting them out" to corporate. Took years before they would speak to us again.
One key we found was to never put one shifter in neutral and let out the clutch. Ours has the neutral selection in the shuttle shift, though.
If the grinding is worse than a slight crunch occasionally, you might have worn synchronizers... My understanding is that these transmissions were so uncommon that parts are NLA...
That's what I have is the synchromesh transmission and it grinds pretty good in the range side. It gets better after it warms up. Hopefully it just needs some
adjustment. Thanks
Shifting faster does not work it grinds too much. It isn't hard to shift out of gear just going in. Hopefully it's an adjustment issue.
Thanks for the info.
I don't have a neutral in the shuttle. Hopefully all it needs is some adjustment.
I have the synchromesh transmission not the powershift. Sometimes I wish I had the powershift.
If I shift the range side into gear and leave the other lever in neutral I can start the tractor and put it in gear with no grinding and I'm good to go. I can also shift the range from 3rd to 4th without any grinding. It's mainly when starting the tractor when cold as in the oil temp not necessarily when it's cold out side. I live in South Dakota and it doesn't matter if it's winter or spring.
The only other issue I have had with this tractor was the fuel system losing prime. Contacted the local dealer and a couple of mechanic friends about this. The dealer said probably the line from tank to pump was cracked and I would have to remove the left rear wheel and drop the fuel tank down. All i ended up doing was remove 8 bolts from the seat and slid it back and the rubber hose coming off the tank was cracked. Easy fix but I wondered if the dealer was screwing the customers by doing what they told me how to get at cracked fuel line.
We have a early 5140 without powershift and only foward/reverse on the steering column. This tractor is a Rops tractor with the canopy. There is a upper AND lower clutch pedal switch on this one. I have had them to get dusty and stick or make it be a slow release being it has no cab. The gear changing is really funny when it does this or it'll set off the orange transmission light. There is 2 linkage rods on the right side that connects the gear levers to the pressure switches on right lower side. I have had one to freeze up and break. My guess would be you've got one of the clutch pedal switches playing with you. One turns a function off while the other one turns it on between gears the way my dealer explained it to me.
When I got this tractor the OEM fuel lines had already been replaced with hoses. I removed the left wheel and dropped the tank, and re-did the job, getting the old rusted lines out of there.
