CAV Lucus injector pump.
Chris Lindon
Members, I have 2755 John Deere with a CAV Injector pump. I need to know the correct governor spring placement. I understand about the code and have a code chart, my problem is my pump doesnt have the code number on it. I do have these numbers on it. Top RE 25698, middle R3449F070, bottom 441889DF. If someone could help me find the code number for spring placement, I would appreciate it.
Thank you.
It's your lucky day, the CAV spec cards USUALLY don't have engine builder part numbers. The RE 25698 is CAV DPA pump 3449F070, test spec shows spring code 8. Lowest hole
in governor arm and center hole in throttle lever link.
I dont know how to thank you enough. You have saved me lots of headache and time. Ive been struggling with this for two days. I sure want to say THANK YOU. I appreciate it greatly.
