chain saw question
jm.
Location
Dover TN
OK drug out two of may dads old chain saws today. Homelite XL ? purchased around 1969 or so. Neither was stuck. Here is the problem with the first one. With ne spark plug you can pull the rope all day no fire. BUT if I put a drill motor on the end of the sprocket nut as soon as it comes up to about where the saw would be running speed the fire is perfect. I removed the laminated coil that the plug wire goes to and cleaned fly wheel and the coil thing. No change so I pulled the flywheel and there was a small aluminum cover. Replaced the points and condenser. Figured I had it , well to my dismay it is still just the same. Don,t need this thing , was just making indoor work in this bad weather but now I want to fix it. Anybody got any ideas.
Check the points with an ohm meter to be sure they are making connection.
Being new and in the box for a long time they may have some corrosion or a coating to prevent corrosion. Even residue from the feeler gauge can stop them from making contact. Clean them with a paper business card and brake cleaner.
I agree the coil is likely the culprit. easier to make spark going faster. I would check the points and coil gap as suggested and if it is still the same, I would get a coil.
I have two old saws I hung on the wall along side a husqvarna chainsaw sign for display there right where they need to be retired I couldn't imagine heading to the woodpile with those things
Thanks guys 58 and pretty here today but I,ll get back on it tomorrow , they are calling for heavy rains. Happy New Year to all and thanks again for the answers, pictures and results to follow some day.
I have a Homlite 707 from the 50s. I doubt it would start and I am not going to try. I would be wore out just carrying it from the truck to the woods.
TF thanks for the answer.. I have three good sthil late model saws, these were just dads and I thought I would see if I could get one running. One fell out of his pick up going down the highway when it was almost new. He doubled up a handle and ran it several years, dont think the second one has that many hours , Ill see what I may need.
IF you go to Leons Chainsaw Repair on You Tube you can watch a Homelite expert in action. IIRC he has stated that baking the coil often brings them back form the dead. I would imagine it's a moisture issue. Might research that, but coils for the XL's aren't that hard to find or that expensive.
