Changing The Dreaded Fan Pulley Bearing On A TW Series.
Noticed while checking the tractor for planting that the fan drive pulley bearing on my TW35 was loose. I learned a hard lesson on my TW20 once upon a time. You know, fan into radiator. The TW35 provided a different challenge. It has the fan clutch. However, once I removed the thermostat housing, the real challenge started. Driving the bearing stem out of the housing was not that bad. Getting the old bearing out of the pulley was. Is there a way to remove the bearing from the pulled without a torch? This is how I've done it in the past.
