Char Lynn Power Steering
super99
I didn't want to hyjack the thread above. I have a Farmall 400 with a Schwartz wide front, Char Lynn power steering and a loader on it. When driving around with the bucket empty, it steers great. With a load in the bucket, it will barely turn with the motor revved up unless its moving. It's a pain trying to load something when you need to turn just a bit and have to have the motor wound up. The torque generator leaks oil all over it from the sides. Supposedly the pump was rebuilt when I bought it, but it has always been this way. Any ideas??
Is your P.S. plumbed to your tractors hydraulics or do you have belt driven pump? Mine is like yours, but the neighbors 450 has a separate pump. After I replaced his belt, it steers wonderfully.
It worked perfect before -- I have had this type of power steering for50 plus years and have not ever had this before now. the belt is tight the fluid is full and it does not leak anywhere . it has its own pump and the engine pulls down a bit when the steering reaches that lock-up point -- Roy
You need new rubber rings on the TG. Perhaps vanes. The rings are square i think.Be sure and scribe the two halves of the case before you disassemble. I did just on a hunch and was very happy I did.
Does the swartz have thrust bearings on the bottom of the spindles? A loader will usually wear these out and destroy them. Replacing them and the bushings plus a healthly greasing will lower the steering pressure. keeping tires at higher pressure will also help steering pressures.
A tired pump will hurt, or a pump set with the wrong pressure on the relief valve will hurt.. as most pump sellers sell a universal pump to fit multi tractors with the relief valve set somewhere at the low end. This means will not preform correctly on the bigger models.
