Dale2
I have a 2000 s10 truck 4 cylinder with auto trans that is my parts runner. Lately is has a strange problem of loosing spark on two cylinders. I have moved the ignition coils around and the problem stays with the cylinders. I have also replaced the ignition board the coils plug in to. Has anyone seen this problem or know where to start looking? Can anyone tell me what signals should be coming to the ignition board and where they come from?
thanks
Dale
Is the check engine light on when running? It should be, pull the codes, see what it says, should be multiple codes.
Have you tried reseating the wire harnesses on the ECM? It should be on top of the right fender.
steve The check engine light has been on for the last 300000 miles. The truck has 421k and runs good when all plugs fire. I was hoping this was a known problem. Im sure it has multiple codes and I will look at the wire harness at ecm
Have you changed plugs and wires? On that system, a bad plug or shorted wire can take both cylinders on a coil with it. Those are just one coil with two towers, the cylinders are paired so one is on compression while the other is on exhaust. When the coil fires, both plugs spark every time, it is called waste spark ignition.
