Cluch Replacement in JD 5310
Anybody got a guess of what the cost (ballpark) is to replace the clutch in a JD 5310? I am guessing the tractor will have to be split to work on clutch.
If I go from 2nd gear to reverse with the clutch pushed all the way in, the tractor moves from forward to reverse (again with the clutch pushed all the way down). Not good.
Is this a South American version? I have a 5403 in Brazil that has a hydraulically operated clutch. If so maybe the reservoir is low,or needs bled,or slave cylinder leaking.Check the linkage/adjustment before you tear into it too far.
If Bolivia is anything like Brazil,the Deere dealer's shop rate is only under $20/hr,doesn't hardly pay to try and do it yourself.
