Continental engine, NO oil filter?
BigGrouch
Working on a very old Towmotor forklift. I think we've identified the engine as a Continental Y112, on propane. I'm not finding an engine oil filter. Could it have been built without one? I think the first 265 Chevrolet engines in 1955 didn't have one, a remote filter was an option. This Towmotor could have had a remote and been bypassed at some point. Any thoughts? Thank you.
Yes it could have had a remote oil filter. We had an old Towmotor from the 50's with a Y series engine and a remote oil filter on propane.
Many old engines didn't have oil filters. Up to you to change/keep oil clean. Some even specified to fill with kerosene and run a minute to flush when changing oil. Many had add on filters as option or installed later.
Those Continentals just had a bypass filter, if there was one. Quite likely yours never had one.
Would look something like this.
That's all they ever had was a remote bypass filter.
You could add one if there is room. They make a spin on with a metering orfice in the filter, can't remember the number, but it has to have the restriction or it will dump all the oil pressure back to the pan!
My first VAC Case didn't have an oil filter. I got a kit from some place that allowed a spin on to be used.
When I was at Lincoln they Continentals they used came in without filters. We had die to make a bracket for a spin-on similar to the one pictured below and fed it from the oil gallery. The Budas used a Kralinator filter like that, too.
(quoted from post at 11:10:06 08/02/21) When I was at Lincoln they Continentals they used came in without filters. We had die to make a bracket for a spin-on similar to the one pictured below and fed it from the oil gallery. The Budas used a Kralinator filter like that, too.
I had to read that a couple of times. I first thought you were talking about Lincoln Continentals. Made me wonder how long ago you worked for Ford......... then, I came to my senses.
