Cover crop wheat
poorboys 151
Has anyone chopped and bagged wheat and made a good feed first year with it . I have equipment to chop but would have to rent a wrapper and hired baled what is best option
You're just talking about chopping and bagging for silage? Chopping cereals for silage is pretty common practice. The chap who trucks our cattle fills several bunker silos with chopped cereals of one sort or another each year. Just chop/bag at the right stage (don't let it get too far along).
I'd be baling and wrapping it if it were mine, but only because that's what I have the equipment for. Or just cut it before it heads and and dry-bale it. No different than a grassy hay (well, probably a smidge higher protein than most grasses).
Alright looks like baling and wrapping is the preferred method
around here baling and wrapping is the most common practice but it will cost $20 per bale for that as I don’t have the equipment
If I did decide to chop before it heads out how long should it cure before chopping
They bale a lot of wheat here in north Texas
Where? Been living on this farm since 1979 and never saw it baled. Around here they graze it during the winter, pulling the cows off and spraying Green Bugs in January (last week in January is usually dry, making it convenient to get machinery on the field) and cut wheat (grain) in late spring-early summer. Putting the cows on it in the winter feeds the cows and I am told it makes the plants sprout new shoots that result in an increase in the wheat production.....win-win deal.
They used to burn the stubble off the fields but quit (reason unknown...probably County ban on burning outside) and now plow it into the ground for soil percolation improvement. I never planted it. Planted Rye Grass instead and baled that in late spring....when I had cows they did graze it like the w-h-e-a t-e-r-s (AI stubbornness in my Apple computer's software) did on wheat fields.
Never done wheat, but I have dry baled oats and rye. Worst trouble with that is the plentiful seed in the bales really attracts rodents. The chew the strings for entertainment, then the bales fall apart when you go to feed them.
I take it you feed this to your own livestock? I would suggest you get a moisture meter and determine when the material is at the proper moisture to chop. I think green wheat fodder is a bit more tricky to get it to ferment properly into good feed. When I search hay moisture meters some come up for around $30 and some are over $200. It looks like maybe the more expensive ones have a single long probe that looks like it might be for stabbing in a round bale. Don’t know where you are do you ever consult with your Extension office? They can be a very good source of information for these kinds of questions.
Most of what I have seen baled in North Texas is after a hailstorm. That said, anywhere there are large dairies in that area they chop a lot of winter forage. Mostly triticale these days, wheat works but doesn’t yield as well. Grow triticale over the winter and follow it with corn, milo, or cotton in the summer.
South central ky is where I live just trying to find other options besides corn for silage due to high input cost
I would pencil out he cost very carefully. corn has way more yield than wheat per $ spent in my books. Now I do not fertilize my corn like everyone else. I spend max $100 acre. I get close to 8 ton per acre. Not huge yield but wheat and oats was giving me 1-1.5 ton an acre. for me hands down the corn came on top. I need less acres for corn and the rest can be combined and sold as grain. That way i plant more incase of less rain and still have enough feed.
If you expect fertilizer prices to drop in the future, for corn you might be able to cut back on fertilizer for a year or two. If you switch crops P and K will stay in the soil, N will leach out of the root zone .
They pee on the wire and eat the string. Years ago, learning about what works and what doesn't, I did plant oats one year and weren't freeze resistant. Didn't do that again. Ryegrass and wheat are.
Yup. If you're dry-baling cereals, you want to cut it prior to heading. Two years ago I had a field of winter rye (cereal rye, not ryegrass) as a cover. The original purpose for it was just to hold the sandy soil together over winter and till it back in the spring (it was a very steep field that's prone to washing out in spring). But it came along so good and we always need straw, so I decided to let it ripen, cut with the haybine, and bale for straw. I don't think I'll ever do that again. Every bale had at least one dead mouse inside by the end of winter. And the barn hadn't had that many mice running around in it since the days we used to thresh in there and blow the grain into an open granary room.
The racoons also came into the barn much more than usual that year - I suspect because they eat both mice and grain, and thus found ample food opportunity there (as well as some nice straw bales to tear apart and make nests in).
