Cub pistons choices
Good grief that was Way back way tomany years ago to remember kit part numbers . the kits were for a 185 head , carb timing changes to the dist. that today who are you going to find that can recurve a dist . Around here i know of no one as i am the last man standing who knows how and still has a dist .strobe machine . Back in my day every dealership had one and one OLD GOAT knew how and few young guys ever bothered to learn the art. I was doing this way back in 1964 when i bought a NEW 1020 Sun Scope and a 505 Sun dist. strobe and went to the classes to learn how to use them . Back then i was striving to build a wild vary fast F E block Ford and go where no one has gone before . I lived ate and drank Drag racing and to build a FORD to RUN and do it all on my own . The only thing i did not do was the balancing as i did not have the means . I did the machine work myself , the Cam came from Cal. special built a one of a kind . When done then came the engine timing and many hours of doing and testing . The testing i had a leg up as my one cousin and a family friend had interest and owned a local drag strip where i could run under the CLOCK during the week . This is where i really learned what a degree here five there could do . Then came tractors and WHOA this does NOT work on tractors so a new learning curve came about to squeak out a couple more horses as now your not talking gaining MORE RPM at higher RPM on a tractor everything works in reverse as load increases increased timing start to KILL ya and now ya need a timing curve to start backing up FAST . to hang out and get down and dirty .
He isn’t asking you about anything. His reply is to member Oregon Tractor Jack asking about the source of the overhaul kit he purchased from his reply 40.
