David Brown 780
larry63
I have a David Brown 780 3cyl that the tractor has been sitting for 15 yrs and the motor was locked up and I pulled the ejectors to pour some marvel mystery oil and let sit for a month and now the motor is free except, one of the lifters is stuck and a bent push rod so how do you get a lifter unstuck?
Larry
If you have a removable plate over the lifter gallery, the stuck lifter can be freed up by cleaning the exposed part of it, then polishing that
part with 600 grit paper, Just remove rust. Then using PB Blaster, or liquid wrench, soak it some. Turn the engine so that lifter is not being
pushed by the cam, and tap it down ward. Turn the engine so it comes up again, and repeat 5 times or so. Eventually it will free up enough to
be pulled out and cleaned up, along with the gallery hole. The bent pushrod is from a stuck valve on that cylinder. It may be unstuck now, but
it was stuck enough to bend the pushrod, so it might need to be freed as well. Let us know. Jim
Jim, Thanks I will look and see if I have removable plate and give it a try, The valve is free.
Larry
(quoted from post at 11:31:13 07/14/20) I Eventually it will free up enough to
on a DB the lifters go out through the bottom end. the camshaft has to come out first. much easier to remove that cam with the engine upside down.
If it was stuck, it will probably run poorly and need a proper overhaul anyway.
Before trying to start it you want to also check the injection pump for rust due to moisture from condensation, and get some oil on the rocker arms. It can take a while for the oil to get up there and the shaft can gall during that interval. Don't ask me how I know.
