DAVID BROWN 990 3 POINT STUCK
francis
hi in alice texas ,this weekend our small david brown 990 tractor was having a hard time lifting a round bale,well without knowing much about it,i turned or pulled the rear lever on the left rear axle,then it raised up,and now nothing will let it come down,
i've messed with the select height lever,,the small finger knob that has 3 adjustments,,and the gear looking handle that moves forward and backward,to try switching modes it might be stuck in,is there anyone out there that has seen whats happening and can adjust me back on the right track?
The lever on the back of the left axle housing is the lock to keep the hitch from dropping by accident. Put the hitch in raise position and rev it up to make sure the hitch is fully raised then turn the lock lever to the other position. Check back with the result. mEl
