I've got a John Deere Industrial 301A tractor that leaks hydraulic fluid from the load control shaft/bushing. I tried to replace the bushings several years ago, but was unable to get them out. I just replaced the seals, but it is leaking badly again.
I looked a YouTube to see if there were any good videos showing how to replace the bearing, shaft, and seals. I found a fairly recent video:
https://www.bing.com/videos/search?q=deere+load+control+bushings&&view=detail&mid=C77F2E6A14EA2143DF69C77F2E6A14EA2143DF69&&FORM=VRDGAR
The video shows a "bushing removal tool" being inserted into the bushing, then the bushing was beat out using a rod from the other side. (The "tool" gripped the machined channel where the nylon seal fit. The metal rod used to beat out the bushing could "bear" on the tool rather than on the edge of the bushing.)
I'm not much of a mechanic, but I have never seen such a "tool" and could not find anything similar with a search of the internet.
Can anyone identify this tool and suggest how or where I could purchase or make one? (The tool looks sort of like two jaws of a small gear puller that are held together with a bolt----except for the fact that the holes in the jaws are at a 90 degree angle.)
