Diesel leak....
Trent D. H.
Massey 245 leaking at the return line at top of the injector closest to the dash. I watched a video of putting the line back on top of the injectors and they didn't have any brass washers like I figured they would. The bolt was tight and I thought I would just check to see if there was a common reason for a leak there. Thanks
The injector top return line bolt washers can be copper or aluminum, two on each bolt.
Thank you! I knew everything I every worked on had some so the video had me confused. I guess I'll order some and check the bolt out good and see if that stops it. Thanks again!
