diesel woes
MI-Bill
1 have a Kubota diesel in a large - 11' cut mower. was running fine. let it set for almost aear without starting. it started and ran fine for a few minutes. I shut it off. a couple of weeks later it would start , but only stay running for a few minutes and not speed up. now it does nor want to start. I did buy fuel at a gas station and not the recommended truck stop. I am guessing I have a fuel problem? considering replacing fuel filter? and ?? when I get it running? what fuel additives should I use? SW Michigan.
You need to change the fuel filet and make sure there is not a water separator. All kinds of fuel conditioners out there Standyne, or Lucas or 911 . Changing the filters is the most important part.
Yes change filters. I would also drain a couple of gallons out of the tank after letting it set over night. Maybe drain whole tank.
Likely just a bad filter. Sitting that long with the fuel level low would create a lot of condensation, so there is likely water in the filters. I would be very surprised if you hot bad fuel tho. As far as conditioners, you will need one that clears water and those are not real common so look at the bottle when you buy.
Like others said,it's most likely a bad filter.The best thing to do,is drain the tank then run 40% kerosene to 60% fresh diesel to clean the fuel tank,and entire fuel system,but you will have to replace the fuel filter afterwards since all the junk from the tank and fuel lines will end up in the filter,so try doing this first to avoid changing the filter twice.but even if you have to replace twice,it is well worth it,since kerosene is far better than any in the bottle cure.
Rock
Your water separator might be part of the fuel filter. I have a Tonks~Toy Kubota with that feature. I serviced it and found the filter housing was partially filled with water and the rest was ugly gunk. Algae treatment might be in order if you let it set a long time regularly.
diesel expert told me in diesel trucks/tractors built before 2007 on road fuel does not have adequate lubrication unless it is added. He suggested adding transmission fluid to such fuel and neighbors with similar problems to yours cured their problem by doing just that. Such advice is worth it's cost. Have a blessed day
Hello MI-Bill,
Replace the fuel filter, and drain all the old fuel out of the tank. If there is a way to drain the fuel pump, drain it first.
After filling the tank with new fuel, bleed each injector line until you see the new fuel coming through.
Doing so will not only ensure you have new fuel all the way to the injectors lines, but you will have also blead all the air out of the system. It should fire off then,
Guido.
