Don't have Spark
Dutchman
Hi all,
I'm working on a Wheel Horse, [ it's a small tractor type .. sort of .. ] , 16hp 2cyl. with a Briggs & Strattion ...
I clean the flywheel magnet [ I think that's what it is ] it's on the outside of the flywheel...
Theres a fork thing , mounted on the engine that the plug wires run from.. [ I'm not sure but think it's the coil ]
I don't get any spark... ARE THERE POINTS SOMEWHERE ???
Does anyone have an idea .. where I should start ??.... or what I should replace ??...
I want THANK YOU in advance ... I do appricate any and all advice ....
Mark
Probably no points at all. Just some internal electronics that dump the magneto primary at a specific voltage. Then the spark jumps. There is possibly a ground wire, and a shorting wire that stops the tractor. If the wire that leads out is disconnected from all switches, and the core is close to the fly wheel (use a .003" feeler, or two sheets of paper to set the gap to the Flywheel) it should spark. It is not dependent on any other parts like the crank shaft key (if the key is bad, it will be out of time, but still spark) If no spark, the only answer is a new mag. JimN
It has an electronic ignition unless it is very old. Yes that is the coil. Most of the time when there is no spark it is because of a safety switch somewhere. There is a small black wire coming from the coil. If you open the wire you are removing all of the safety switches and ignition switch from the circuit. The ignition switch grounds the coil to kill the engine. If you disconnect the wire and it starts, you won't be able to kill the engine except possibly chocking it, but that is a fast way to check safety switches and ignition switch to make sure they are not causing the problem.
That engine probably has the Magnetron armature (coil) and doesn't use points. Touch the magnet with a flat blade screwdriver to see if it will attract that screwdriver. The magnets may weak, but if attracts the screwdriver the magnets are probably ok. Clean any rust off the magnet. The
Magnetron armature is probably the culprit. New ones should be available. They're not cheap. Hal
PS: Three days of rain here in MD.
Here's a picture of a Magnetron armature used on some B&S engines. They fire when the magnet passes by the armature. No points are used. This one cost about $37.00. Hal
I remove the little black wire .... I HAVE SPARK ... put a little gas in plug holes and put the plugs back in and had it running [ for alittle bit ]
THANKS to ALL that gave me advice ...
Mark
