Loading some sand and suddenly the left track went sloppily loose. Its a grease activated system. Pumped grease into it today and as the track tightened
grease was coming out between the fixed and movable sections. Probably a blown seal or o-ring. Can't see any easy way to disassemble for repair other than take
the track apart and slide the front wheel assembly ahead. Has anyone worked on one of these? If thats the only way to fix it is there a chance to jury rig
something to take the place of the tensioning system. Think I'm going to try to fasten a couple of short oak 2x6 in place to hold enough so I can drive it home.
about a mile across fields. is there a super lot of pressure on this area? , do you think I could make a cobbled together system work. Doesn't get used a lot.
Just occasional jobs on the farm. Thanks
