drive shaft seal replacement
beercase
My 1950 Case VAC serial no. 5456226 is leaking hydraulic oil from the torque tube into the transmission. It appears be the main drive shaft seal(VT-4970) that is the problem. Do I have to split the tractor to replace that seal or can I access it through the shift lever cover on top. Any help would be greatly appreciated. Thank you in advance.
