Eric in IL
This motor is a 110 volt, 1/3 hp that is used on a grain bin spreader hanging from the roof. This fall it only worked for a couple loads. Then it would just hum when switched on.
I removed the motor a week ago. The capacitor looked ok visually so I took it to a motor shop yesterday. He tested the capacitor as being good. Hooked it to power and it started fine. When it coasted to a stop I heard a click making me think it has a mechanical starting switch.
I told the shop owner to put in some new bearings and take a good look at the switch. This motor starts or cycles 3 times a minute when it is in use.
Do you think I should just have him replace the starter switch ?
