tractorkrum
Hopefully some one can explain this to me. I have a Delta table saw with a on and off switch with a reset button next to the switch. The motor burned out and I installed a new one. The motor came wired with three wires and the old one was wired from the switch with four wires. Three wires (black, white and green} went from the on/off switch and the fourth wire (red) went to the reset switch. The wire from the reset switch was capped off at the motor and not attached. I thought the reset switch worked when I was having problems with the old motor, but now I am unsure. So the question is does the reset switch wire need to be attached to the motor to work properly and if so where does it get attached?
